I'm even glad that I'm not driving my wife's Supra at present or probably would get done too. My say Supra FTW.
Here's how we drop the crime rate. We had 1000's of garbage bins getting stolen so instead of reporting them as thefts we were instructed to get people to just fill out stat dec for council to replace. Instantly we had a major drop in reported thefts surprise surprise
