Urgent: Picture of R34 injector
Any of the R34 GTt guys out there that can send me a picture of the side of one of their fuel injectors. I need to clearly see the code written on the side of it. Or better can someone just give me the code number printed on one.
They’re not hard to see once the top plastic cover is removed.
Needed urgently!
Dan
https://www.sau.com.au/forums/topic/31852-urgent-picture-of-r34-injector/
Ian they haven't arrived yet...I'm getting worried as the car goes in on Monday for the turbo.
I may have to get a basic tune, or limp around with the wastegate open until I can put them in.
thanks for the numbers
Dan
I'll give the royal mail a bollocking in morning to see whats been happening because it's been nearly bloody 3 weeks, sorry about this mate  :Oops:
haha looks like I've got the same luck with the UK post as I do with Australia post :P
Eek car goes in Friday now....one day left!
