Im about to pot rivet in a new firewall over my fuel cell in the back of my track car. I want to use some kind of bonding material (like the factory stuff) to seal it, stop it rusting and resonating.
What to people recomend? Im assuming you can get some kind of sikaflex stuff in a caulking tube? It will be bonding a 1.2mm alloy sheet to the original metal floor to fill up this space:
personally i would use nut-serts/rivnuts to bolt the panel down and seal it with a stick on foam seal
but yes sikaflex will create a strong bond and comes in caulking tubes from supercheap etc
The panel in question goes around the battery box and the tank filler... so it can be quite permanent, there will be a foam sealed hatch over the fuel filler for obvious reasons.
I guess Ill just have to ask at the shop what particular compond to use, as there are a heap of different ones available?
been driving the car around a bit tonight with the ally sheet just sitting in there - while making up the exhaust. It was actually suprisingly quiet, I was expecting it to resonate like a drum.
I think Ill just leave it till I strip and paint the interior, then just rivit it down with a bit of silicon or something.
Edited by samstain
  • 5 weeks later...
Marine grade 3M 5200... It will stick almost anything to almost anything. Most superyachts are held together with 5200!!! Ha ha ha... No really.
3M is heat resistant, flame retardent and chemical retardent. It's also the only product that Yach Insurace companies allow to be used as a sealant below the water line.
It's so frekin sticky that 3M had to produce a removing agent- nothing else will get it off.
J.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
