hey im half way through taking apart my car for the new timing belt and i see something that worries me, there are white painted on marks at 12 oclock on the cam gear and behind the cam cover, like instead of using the factory marks someone before made their own. If I rotate the motor the factory ones line up ok, but if i turn further the home job ones line up but its def not at TDC. What does this mean for me doing my new belt just use factory i guess, unless they had the cam gears off and rotated them or something, i dunno, what do yous think?
https://www.sau.com.au/forums/topic/318584-home-job-timing-marks/
Interesting....
Did you check your base timing with a light before you started? If so what was it at when warm with a/c off?
I personally would disregard these home jobbies and line up the factory indents on the gears with the marks on the engine cover.
Hows it all going anyway?
it means whoever did it wasnt to be safer then sorry.... there is nothing wrong with whats been done, infact when you change the timing belt it doesnt even have to be at TDC, its just easier becoz the cams wont jump side to side easily....
i make my own marks on all 3 gears simply becoz its easier to see my own white marks, on top it is alot easier to get dead straight aswell....
just forget u saw them and proceed.....
as you can see, cams timed up, and the balancer isn't straight up and down.
plus the timing mark on the crank appears to be out a small amount too, looks ok from the top but from under the car looks out
Edited by horrace
it just seems like the crank is out by 1 tooth, but i mean the car runs good so i dunno, i checked the timing before i did it and it was 20 deg, but that was using a cheap light and my limited knowledge.
come to think of it with the balancer on the mark lines up with the one on the timing case so it must be ok!
Edited by horrace
i spent weeks trying to do the cam timing on a single cam rb20e . eventually found out the mark on cam pulley is supposed to be at the top . tried that . triedup to a few teeth either way aswell . stil shit hack . it ran but obvoiusly not the best . looked at diagrams in the book then realised
well I finished yesterday as it was getting dark and the car is running sweet, I took if for a gentle spin last night then I warmed it up this morning and set the ignition timing back to 15 degrees and all seems well. Thanks to everyone who helped me with my noob questions and problems!
this is the exact reason people make there own marks.....if the engine is running beautiful, its somes alot easier to make 3 of your own marks, transfer them onto the new belt and line them up again spot on, and u know your right the first time.....
sumtimes u second guess yourself on the crank one becoz of the stupid angle its on.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
