HKS Twin power-$300
HKS Type R intercooler(core only)-$400
Nismo front bumper clear winkers-80
stock aluminium radiator-$100
Japan STOUT RACING carbon bonnet-$900
Condition and pic of intercooler please. or call me on 0433 878905 Alex
https://www.sau.com.au/forums/topic/318823-bnr34-sales/#findComment-5211111
