FOR SALE
88 FC3S RX7 GT-X
jap import 13BT
Grey interior (good condition)
car has 6 months rego
112932 km on the clock
Extra Info
Fujita Engineering/FEED 60-1 High-Flow turbo
This turbo is very inconspicuous and is rated to 400hp, also has HKS adj. actuator
GReddy gauges 60mm - Warning Meters, Boost/water temp/oil temp/oil pressure with full memory recall
Nardi classic wheel
Gear knob
Drift Handbrake Button
Recaro Drivers seat on Bride rail
Series 5 tail lights
Microtech mtx-8 (just tuned at revs, running very nicely)
Pod filter
Trust bleed valve currently running 8psi (very safe)
Exhaust Technology 3 inch dump, front, high-flow cat and exhaust
New cooling pro intercooler/pipes tested and no boost leaks
Bosch 040 fuel pump
Exedy clutch with lightened flywheel
Shimmed S4 LSD
Rear battery location
Car no longer has AFM due to microtech computer, but still runs OMP
Flared guards
RIMS D1R wheels, Silver/polished lip, 17 x 9 +30 and 17 x 10 +15
TIRES 215/45 Kuhmo KU36 semi comp R and 235/40 Kuhmo P716 Admiral tyres
Both rims and tires are in very good condition and are like practically new
Kei Office Coilovers (10kg/8kg) very stiff
Cusco Tower Bar
Brand new leads and plugs
s5 front bar
Extra stock parts
Original driver’s seat
Original suspension with king springs
Original turbo
Stock ecu
most parts like vac hoses ect to return car to stock
Pictures
Pretty much everything i can think of for now
The car has just been to revs and has been compression tested and tuned so it running very nicely , car is always warmed up and cooled down. car gets regular oil changes/ has new plugs. car has also just had a wheel alignment.
swaps
AE86 or mx-5 or lams app bike plus cash my way
Price and price conditions: $9500, please note this is negotiable there are lots of parts i am willing to take off to get price down
Contact: Pm me and if your serious ill give you my number
https://www.sau.com.au/forums/topic/318923-fc3s-jap-import-sa/
Please stop bumping your thread, else I will delete it. If everyone did this to all their threads, it is all the forums would be full of. Put it on CarSales ffs.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
