i have an rb25det power fc and hand controller.
im not willing to seperate at this point.
in perfect working condition. all data has been wiped on it so its ready to go from a clean slate.
can run on any series one or two rb25.
will not run on a neo rb25
price is $1500 posted anywhere in australia
or picked up in toowoomba, qld
contact by pm or [email protected]
https://www.sau.com.au/forums/topic/319219-rb25det-apexi-power-fc/
  • 4 weeks later...
I'll give you $600 for ecu, dont need hand controller?
is this still for sale?
may need one... will know 100% by this wednesday.
WHy are you selling it?
thanks!
still for sale.
im not using it and my car will probably be sold before i have time and money to use it :banana:
I will buy the hand controller for a reasonable price if you can seperate
really only wanted to sell it together.
if you just want the hand controller i might be able to get you one. send me a pm if you want.
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
