Hey guys
Change of plan can't get pistons made up for my car for 8 weeks so not rebuilding atm, im just going to buy a second had neo motor and smash it in for the meen time.
My original motor (rb25det neo) has had the vvt disconnected, ant reason for this? and what can i do with the other motor being installed in regards to the vvt swap everthing off the old motor?
Apparently in japan it had gtr cams put in but yet to conform it, the cams are out but need to measure the lift... What is the standard lift?
Also the injectors are blue and top mount. the only numbers i could get was EBJE100 any idea what they are? couldn't find anything on the net.
Cheers
I just measured my cams and i have
Inlet 86mm
exhaust 82mm
That means they are gtr cams
Standard neo are
inlet 84mm
exhaust 87mm
Just wondering if i replace the original cams in the second hand motor with the gtr cams and disconnect the vct is that all i have to do to make it work?
    • No, so what happened is. I put a bunch of filler then I sanded it all down, I removed all the filler (unintentionally), then I put the epoxy primer on because that section of the panel is bare metal. The car is parked outside so I needed to protect it in the meantime incase it rains.
    • It’s definitely an import, the Aussie ones have reflectors in the rear bar, it’s also a turbo which none of the Aussie one were.    I remember back in the day I want a twin turbo z32 so bad and then I saw a 32 gtr and that was the end of that lol
    • Same can be said for Subarus motors ha ha!   I like the 300ZX, I nearly bought a Z32 before I bought my first Skyline. It was going to be a project. Then I found out there was a bit of a dodgy title with it... As in, someone attempted to commit insurance fraud with it and there was now some dodgy legalities around it. So at 18 I walked away from it.
    • The below is what the readings I had with the fuel pressure gauge which were correct. It seems like the issue is mainly during drive and not idle. I bought the new hanger hoping it could be the issue, perhaps I ruined something while cleaning, but I have not installed it yet since I have to wire up everything with the new plugs.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
