  • 2 months later...
so paul has dissected my motor a while ago now, check the attached photos
worrying stuff!
The original builder did not clean the crank, hence one of the oil galleries got clogged up!
which explains the bearing issue!
Luckily everything else was able to be salvaged!
The water pump also started leaking as wasn't sealed correctly and im not even going to get started on the "extended sump"! in Pauls words "its the worst sump ive ever seen"
Original builder should stay away.. far away from ever attempting to build another 26 :spank:
SHIIIITTTT!
thats just disgusting how a business can take your money and do poor work!
atleast the cars in good hands now!
yeh mate.. Pauls showing it some much needed love :3some:
if all goes well, should have it back end of next week or week after
Just read the whole thread, looks like I missed alot of it...
If I was a betting man, i'd say that *********built your motor? I say that based on my own personal experience with an SR I had built by them many years ago...if im right, it would seem he still has no clue about putting Jap motors together...glad youre getting looked after, from all accounts your motor is in good hands, good luck with it mate.
Edited by SLED
You're sailing pretty close to the wind here champ.
I suggest you go and familiarize yourself with the forum rules before even 1 more post.
  • Nope 1
If I was a betting man, i'd say that ******built your motor? I say that based on my own personal experience with an SR I had built by them many years ago...if im right, it would seem he still has no clue about putting Jap motors together...glad youre getting looked after, from all accounts your motor is in good hands, good luck with it mate.
You guess... WRONG :P
ive put a few engines togther over the years but when it comes to high revving long crankshaft engines its best left to the guys who really know them inside out.
Red R build more RB's than anyone in this country and thats all they do. It was a simple choice to make when i decided to throw some big bucks at my current engine.
What a story, just read the whole thing.
Just goes to show that there is no substitute for experience. Good to see how generous people can be in times of need.
Hope you get it all going again soon, it's a very tidy rig.
all the best mnate.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
