Looks awesome David - glad to see it is finally back on the road. Now you need to join up to SAU:SA www.sausa.com.au and come on our upcoming Members only dawn cruise and show it off! Then the SAU Nationals are 28-30 October and you can come over with all of us and race it at Winton :D
Is it a rear Nur engine, or did you just paint it?
You can use paint cut and polish to remove the water marks. If they are really stubborn you can also try some of that CLR Clear stuff on a rag(diluted), and then polish it afterwards.
I had water marks over most of my car and ended up having to 2000 grit wet sand and then PPG system one cut and polished the whole car. It works on glass too. Taking it to a car detailer would have been a lot easier...
Online membership form completed :thumbsup:
Won't be able to make the nationals this year, just happens to be the weekend of a mates wedding.
I have met a few members over the years, but am looking forward to coming to some club events and officially introduce myself and the car.
ps.. the covers are just painted
Edited by Nightcrawler
I've tried cut and polish.. I thought acetone might have done the trick, but still no good. I guess CLR and see if I can sand it back?
I watched a detailer on youtube do it, they make it look so easy.......
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
