For sale are my used Racing logic Coilovers.
These come with 5 spring sets, 12,9,8,6,4Kg/mm
Perfect starter pack for anyone who wants to get into circuit work or drifting.
Rear shock units were replaced with new items about a year ago.
These have adjustable preload as well as base height. This means you can dump or raise the car without having the springs come loose.
The compression/rebound dampening is linked with the one removable, adjustment knob.
All this is supplied with adjustment spanner, dampening knobs and spare shock insert.
Coilovers are currently fitted to a Z32 but will fit an R32 GTR and possibly a GTS-4
$1000 or ONO
Front
Rear. 4kg is a king spring hence its yellow.
Extra springs, 12kg,9kg,8kg.
Price Drop $800
You interested in selling a pair of springs by themselves?
I'm looking for a pair of 4kg/mm, what are the dimensions of the king springs (free length and ID)?
Also where are you located?
Hows the z32 handle with these.
What springs are currently on them.
What is there conditions. Any defects etc.
Where are you.
Cheers
Handles like its on rails but its a bit bumpy. You can really feel what the car is doing. Fronts are still the original shock units but as I said the rears have been replaced. It currently has 6kg springs on the front and 4kg on the rear. The only defects are just usual scratches from installing and removing them. Im in Arundel on the GC.
What were the original springs rates that were on the shocks.
When you replaced the rear shock unit was it matchd the 4kg spring or 8kg,9 spring.
Original was 12kg/9kg. Matching wasnt necessary as dampening is adjustable.
  • 3 weeks later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
