My rear right HICAS arm ball joint is stuffed and has lots of play, I have bought a replacement and had a shot at replacing it tonight but got stuck.
Basically I jacked the vehicle up popped the boot off the ball joint and got the shifter on the flat sides of it. Took a bit of a wrench but it cracked and I sat there turning it for ages. It was tight so I assumed I was undoing it but after 10 minutes it didn't seem to have really moved. Am I doing it wrong or is the pressure of the wheel holding the rod in there and there a trick to getting it undone?
Cheers :P
Edited by Rolls
what is the other side joint doing?? , i vaguely remember having to hold one side whilst i loosened the other (feel free to correct me if i'm wrong , it's been a while)
This is what I considered but a friend of mine who had done it on a R33 said I should only need one shifter, unless of course R32s are substantially different.
I didn't take the boot off the other one though so I couldn't see if it was spinning, will check that first if no one else has any other tips by tomorrow.
Thanks.
All good I got a mate to come around with his rattle gun and we figured it out.
Was correct assuming that you the rack is a solid bar that spins, so I have to use two shifters, one to lock the other side and undo it that way.
Car drives much better now without the rear end shaking, also means I should pass regency with no hassle.
Thanks for the comments anyway!
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
