Does anyone know if you can just apply straight power to the afc via battery or whatever to power and ground (i think theres 2 power wires)
just to test if it turns on. or does it need proper sensor input aswell.
See it was in my rx7 when it caught fire 2 years ago and was blasted by water so id like to see if it turns on so i don't end up wiring it in my r33 for nothing.
I also havent read of anyone who has had a water damaged afc nor found any sort of warranty info on them.
So yea, has anyone ever done this before and is it possible.
and yes i know, im gonna have to just try it but i figured i'd ask.
  • 4 weeks later...
i tried.....
so far i have tried to connect the 2 power wires+ illumination to positive on battery,
and the 2 ground together to a ground.
nothing happened.
anyone think im doing something wrong or...?
is there an easier way that someone can think off?
there is no more simple way than just connecting it to a battery. just double check that you were connecting the right wires. should be red and red/white to positive and brown and black to negative. don't bother touching the illumination wire as i think that simply dims the screen. if you have done that and nothing happened then i'd say the unit is dead. i'm not sure if they have a fuse in them that can blow. might be worth looking into that
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
