somewhere on the motor assembly. you just have to look around, sorry can't help you anymore cos I'm not pulling my door apart again after spending 5 hours to get to my passenger door lock actuator! (posted a thread here too about that)
I found it on Pg 10....
Ok mine is working like new again after doing the simple reset. I thought I was gonna have to take out all of the bolts again but Nissan/Infiniti made it easy to reset the motor.
I dont know if I missed it, but to do the reset remove the 3 bolts holding the panel and it is behind the smaller sticker on the metal door piece. Remove the sticker and its a little nipple poking out.
With the door open roll the window completely up without using the auto function. (Barely lift up until the window rolls up.
Close the door with you inside the vehicle.
Hold the reset button down while you press the window switch down to roll the window down. Do not use the auto roll down.
After rolling it completely down give it a couple seconds and then release both buttons.
Now you roll the window completely up without using the auto function and give it a couple of seconds before releasing.
Now you should be good. Roll down the window to open the door from the outside.
  • 1 month later...
  • 1 month later...
Hi guys,
I was having the window issue (passenger side) a few days ago and ended up cleaning out and reseting the motor. It worked for 2 days and then today coming home i put the windows down. a few min later I felt a bit hot and noticed it went back up on its own!! Tried putting it down again and no deal. Also the auto up/down when open/close the door isnt working again. Annoying!!.. specially when you put a couple of hours worth of work into it a few days ago... Anyway.. just wanted to confirm your thoughts, definately motor that needs replacing? or actuator? Where exactly is the actuator? Throughout all these DIY's i saw a lot of motor accessing/cleaning stuff but no actuator.. Forgive me if im blind..
thanks
OK I got the know how to reset the motor. If your window wind down when you auto wind it up, or wind down when you close the door. Here is what my Uncle told me to do. He is a mechanic in Nissan Service Centre in Ipswich Motorway. After you take the motor with the gearbox out from the door frame. Plug the electrical back and turn ignition on. Start winding up or down the window using the switch, looking at the rotating shaft, count 8 numbers of turns. That will reset the motor and the limit switch.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
