My RB25 did exactly this same thing when it had the twin turbo setup. It was due to the turbos forcing more air than the engine could take at low rpm so the air choofed back thru the filters. At top end this problem was gone and made good power. (399rwkw @ 17psi)
I changed from the twins to a T51r and the problem was gone. I was told it will damage the turbos as the exhaust wheel turning one way and the extra air trying to turn inlet wheel the opposite....
So is this true that it can damage the turbos mate?
Can anyone verify this?
I might have to fix it by going back to the plumback setup if it is.
Ah ok i was going to say the power sounds about right for 1bar give/take, and given a built motor crank it upto 20psi and see 380rwkw :)
Comp surge especially whilst building boost is bad, you are fighting two forces at once.
Backing off throttle isn't such a worry though (the other type)
I was told by a few places that it puts added stress on the turbo shaft as the wheels try going different ways as the pressure comes back thru the compressor cover.
I also tried the same twin turbo setup on a 25/30 and had the same result just with the choofing noises at lower revs
Maybe a question for the tuners....
Would it make much of a difference changing the cam timing to clear up the surge...?
So how exactly does the plumb back setup solve the problem?
Wouldnt the extra air that is escaping through the compressor cover still escape, only instead of escaping all the way back through to the air filters its just get resirculated back into the intake?
Im just trying to understand how the plum back would solve the issue of too much air geting forced into the engine at low revs. As surely the same amount of air is geting fed into the engine plum back fitted or not........?
Have a read of this thread - http://www.skylinesaustralia.com/forums/Gt...-F-t160901.html
It can be tuned out. It's also possible your wastegates aren't set the same causing one turbo to try and run more boost.
I run the trust/greddy piping too with hks 2530s but i have the standard bovs. Only rarely got the shuffling going up a hill in 5th.
Thanks heaps for that man. Thats exactly what I was after!
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
