R34 GTT NEO 5 SPEED GEARBOX
Uses a pull type clutch. Gearbox has input shaft bearing noise. Basically a noise that occurs when your off the clutch, obvious noise when your stationary and in neutral. You can hardly notice it when your driving normally. Gearbox has crunched in the past when going in to gear on the odd occasion. Since putting fresh oil in it has been perfect changing gears. Gearbox probably has a fair bit of life left, the sound just annoys me.
Looking for $600 or nearest offer
Cheers
Nick 040262197.4 or PM
https://www.sau.com.au/forums/topic/320369-r34-rb25det-neo-gearbox-sa/
Hey mate
Who diagnosed it as a input shaft bearing? Could be the throw out bearing for the pressure plate. Unless pull type clutches are different but with the noise going away when the clutch is pressed in that tells me its the throw out bearing.
Im a diesel mech and also done the throw out bearings in my both my rx7s as they made a similar noise..........could add more $$$$$ to the price
Giulian
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
    • I use FCC car launcher. It has an option for different backgrounds, so instead of turning the screen off you can swipe 'up' to a black screen with no background/icons. (mine has the time on it only). It's kinda nice. Also lets you use gestures to say swipe to go to next song, etc.
