hey guys my 34 sedan has a heavy duty clutch fitted (not sure on brand etc) and ive been driving it with this clutch for like 6+ months now and its always had heaps of compression and its been relativley hard to push in (well nto hard but not all soft and sloppy) this afternoon i hopped in my car and noticed straight away that my clutch is all soft and has ALOT of freeplay in it... i mean almost to the floor just a few inches off the floor then it gets hard again at the grabbing point...
just wondering if its meant to do this over time it "beds" in or something or do i honestly have something gone wrong?? clutch fluid is all good no problems there..
cheers
https://www.sau.com.au/forums/topic/320435-clutch/
does the clutch actually work correctly?
Either way, sounds like something could be wrong. I had something almost exactly the same happen in my VL, driving up the highway, clutch in to go 4th to 5th, clutch was unbelievable soft, and only felt like it was doing something *JUST* before it was completely depressed.
Turned out to be the master cylinder (I think....the small one where the reservoir is). There is a spring inside that which had broken into 3 pieces. I didn't quite understand what it did, but as a result of being broken, it was essentially shorter. Didn't do what it was there to do until it was almost completely depressed.
Just my 2c. If it turns out to be the same thing, the spring was like $5 from somewhere that just happened to have springs the same size (wasn't genuine). So VERY cheap fix if you can do it yourself.
https://www.sau.com.au/forums/topic/320435-clutch/#findComment-5230539
yeah the clutch works properly soon as its past the grabbing point when letting the clutch it its just soft as nething..... and the grabbing point is literally soon as i lift the clutch off the floor its grabbing so over 3/4 of the pedal is just free play until i hit the floor almost.. whereas before it was pretty hard all the way thru which is wat i liked... my friend who has also driven the car said its definitley different but he said if its any consilation thats how his clutch feels and it doesnt feel burnt out (ive only recently just got my p's so i havent been driving manual for years and years) so yeah ill get that spring looked at though and hopefully thats wat it is :P
cheers mate!
https://www.sau.com.au/forums/topic/320435-clutch/#findComment-5231461
It may be that there was something wrong before with a really heavy clutch pedal that has now resolved itself. I have a heavy duty exedy clutch in my car, and it feels about as heavy to the foot as the factory clutch. Certainly nothing like the crazy eXtreme clutch I used to have fitted to my N14 SSS that was a complete ass to drive in traffic.
If you're concerned - take it to a brake/clutch specialist and get them to drive it and put it up on the hoist to check master/slave cylinder - they'll probably do it for free. At least then you have some professional advice.
https://www.sau.com.au/forums/topic/320435-clutch/#findComment-5231560
went to hop in it tonight to move the car for my old man to put his ute in the garage... no clutch at all.... push straight to the floor it grabbed soon as i let the foot off the floor i thort far out this is worse.. went to put it in first.. car didnt respond at all let the car roll for a bit pushed the clutch in and out didnt even react... no clutch wat so ever.. eventually managed to just clonk it into first the clutch jus grabbed and i quickly put it in the driveway...
hopefully its just my master cylinder or a seal of some sort not letting fluid/pressure through????? also how much wud a master be fitted? cheers
https://www.sau.com.au/forums/topic/320435-clutch/#findComment-5232514
if it's not a leak, DEFINITELY sounds like my problem. Fluid was on max when I had the issue, and car was unable to be driven. I had to be hardcore and rev-match as far as I could to get home as luckily I was already moving when it happened. Got most of the way home, then couldn't get 3rd and had to pull over :P
I'm putting money on the spring in the master being broken. Sounds exactly the same as the VL clutch.
https://www.sau.com.au/forums/topic/320435-clutch/#findComment-5233901
ok so my mechanic said bla bla bla cant adjust clutch since its hydraulic.. so we got onto adjusting the pedal...
now the pedal pressure is great just teh same as before i love it - its not soft anymore - but the release point is really really really high... like literally a few inches before the clutch is completley up, then it grabs...
my question is if i adjust the pedal back down so the release point is where it was before (just below half way when clutch is depressed, i loved it like that) then will the pedal go soft again?
if it does go soft again... wat is actually wrong?? i got the master and slave diagnosed and they are both functioning correctly so wat else cud go wrong?? its a heavy duty clutch and its done probably 10-15 thousand klms only since being put in
https://www.sau.com.au/forums/topic/320435-clutch/#findComment-5243324
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
