1994 Nissan Skyline R33 GTST, Series I factory M-Spec.
This car is in excellent condition; it has been meticulously maintained and always garaged.
It features the following modifications and accessories:
Engine:
RB25DET,
K&N Pod filter with heat shield, (also have standard airbox)
Larger side-mount intercooler from R34GTT,
80mm Bee*R mandrel bent, stainless steel exhaust system with split dump pipe off turbo and 5 inch cat. High flowing but not loud.
5 Speed Manual, Limited Slip Diff,
Odyssey Battery,
137,000kms
Body:
Genuine Nissan body kit with genuine electric sunroof and driving lights,
Nismo clear side indicators,
Drift style rear spoiler,
17 inch Stern wheels, 90% tread on tyres,
Tinted Windows,
Black number plates,
The body is very straight with only a couple of small car park dents, some minor scratches and small stone chips,
Custom suspension:
Bilstein shocks, Whiteline springs, (height adjustable via circlips)
Whiteline adjustable front and rear sway bars,
Whiteline adjustable suspension bush kit, including rear sub-frame alignment bushes,
HICAS lock bar,
Front strut bar with brake master cylinder brace,
Interior:
Nardi steering wheel,
Nismo gear knob,
Drift boost gauge with A-pillar mounted pod,
Auto Turbo Timer,
Pioneer CD/MP3 Player,
Climate control air-conditioning,
Power windows, Power mirrors,
Mongoose M80 Black wire alarm system with 3 point immobiliser and central locking, (insurance approved)
I’ve owned this car for the past four and a half years and now selling due to changing priorities. I need a tow vehicle so the Skyline has to go.
Price: $13,000 ono
Ph: 0407005654
Car is in ACT.
Edited by Tarmac-
https://www.sau.com.au/forums/topic/320579-1994-r33-gtst-series-i/
  • 4 weeks later...
  • 3 weeks later...
