hey guys as above i have a 1983 R30 5 door Hatchback with L24e EFI
wat im asking for is info on the motor, gearbox and diff in detail if possible
i have the basic outline of the suspension so thats not a worry, just the drivechain sides
Thankyou in advance
https://www.sau.com.au/forums/topic/320765-1983-r30-5-door-hatch/
  • Replies 64
Hi,
Check for air leaks; perished or split rubber hoses and loose clamps.
For detail on engine, gearbox and diff you'd need a service manual. There's one on eBay, http://cgi.ebay.com.au/ORIGINAL-NISSAN-SKY...52?cmd=ViewItem
JH
Hi,
JH
g'day JH cheers for the reply, have inspected rubbers of all sorts and electrics but can only come to the cold start mechanism as it doesnt like idle wen cold start (idles irratically) and there seems to be an issue with the TPS as connecting/disconnecting and adjusting made no difference....
hahaha nice find on the manual i already was watching it but thankyou for taking the time to find it!
but i also have the problem of the r30 being sluggish during idle to around 3500rpm then picks up, aswell as between idle and 3500 it seems to have a slight miss too... if that helps
the only thing that isnt original is that i had installed VL RB30 Injectors due to originals #1 and 2 leaking real bad
....as it doesnt like idle wen cold start (idles irratically)...
Hi,
Check the air regulator (see blue circle in the pic). The regulator opens when the engine is cold and then closes when the engine has warmed up. Make sure the air hoses are clamped up tight and the connector is OK. You might have to remove the hoses and check that the shutter inside rotates.
Don't know about the injectors, someone else will know.
JH
Hi,
JH
when u say check the rotation of the regulator which hose should i pull off whilst the cars running i assume? i have pictures as follows
Hi,
In your pics, you should be able to poke a flat bladed screwdriver into the hole, find the edge of the shutter and gently lever it open. It should open and close smoothly. Also, you can check the resistance across the two electrical connectors (should be about 70 ohms).
If it's still on the car and all connected... with the engine running, squash the rubber hose between the front of the regulator and the throttle body. If the engine is cold, squashing the hose should decrease the idle. If the engine is warmed up, squashing the hose should have no effect.
JH
Hi,
JH
that checked out all OK as soon as the hose squashed on cold it stalled, also it just seems to go thru fuel like no 2mora :)
after it warmed up it didnt make a difference via squashing hoses
Oh well, there goes that theory. Air regulator seems OK.
So the engine: won't idle properly when cold, is sluggish to 3500rpm, has a 'slight miss', consumes lots of fuel.
And you've checked: No obvious intake air leaks, air regulator OK, electricals OK.
Suspects: TPS (I think it's only an on/off switch with no adjustment). Two injectors replaced recently.
See if anyone else can help diagnose the problem. BTW how old is this engine?
cheers,
JH
correct
correct
im having the same thought too as i had no response when connecting/disconnecting/adjusting etc
sorry i should have been more specific - ALL injectors where replaced with RB30
203,000km's
cheers,
JH
Edited by RiCkY TuTtY
correct
correct
203,000km's
I got a few of those, dont want them. $50 an ok price?
Thankyou in advance
Swap you a mars bar for it
I reckon if the TPS is buggered it will make the car only rev to 1500 to 2000 rpm.
another thing worth looking at is the water temperature sensor, that actually goes to the ECU. if it is buggered, or the wiring is corroded it will not read the engines warm temps, thus thinking its 'cold' and dumping fuel in.
And another culprit is the cold start injector. is a separate injector that operates on startup only, if its stuck open it will be dumping HEAPS of fuel down. that nasty thing can really cause problems....
it could be just me then with the TPS just because it did nothing to watever i did with it :P
there is a set of wires that run to the dizzy/temp sensors but there is one single plug (flat-single) that when i connect it the actual temp gauge goes thru the roof! but as soon as i disconnect it, the temp reading goes back too normal? :/ - I will post piccies soon
where abouts would this cold start injector be if i may ask? :ermm:
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
