hey guys i am the pround owner of a 92 gtst type m, currently my car is basicly stock (enginewise) with a few minor mods such as
- 3inch straight through exhaust with twin 3inch muffler
- gizzmo MS-IBC
- bmc high flow panel filter
it has a bad missfiring problem! i have changed the plugs check the coils all in working order, changed the feul filter basically service the whole engine bay but cant get ridd of this missfiring problem, it generaly happens under hard boost from 5000 rpm till redline, ive basically brang it down to a computer problem. on the cards however is a nistune remap and dyno.... but before i did that i have planed on installing a vg30, plus frount mout, and proper CAI System on the car.......
what are your opinions Remap first then mods or live with it for a couple of months until mods are done and the remap?
and any advice or input on the missfiring would be appreciated?
cheers Joe
https://www.sau.com.au/forums/topic/320811-rb20det-miss-fire/
i have the same problem when it's cold. i've heard it's the computer spiking but i'm not exactly sure what that means. there's a popping sound and loss of power when it happens? it's not when my engine is cold but the temp outside. i think the cold air having more oxygen might be the problem.
my theory with mine is that a sensor is not working properly like the sensor that is supposed to change the mixture in high altitudes? this excess of oxygen might be causing some fires to be a bit too rich or lean.
mine doesn't hapen very often at the moment though but when it does, MAN is it a disappointing feeling...i'm not sure how to fix it man but when you find out i'd love a PM!
cheers
If the ignition system seems to be working properly then maybe you should start looking at fuel system.
Good luck with the trouble shooting mate.
hmmm yea i changed the feul filter next i gess is the pump or should i check somthing else in the fuel system first?
cheers mate
Could be many things when it comes to miss firing, you can try clean your AFM with CRC contact cleaner.
Also check the injectors and wires that gose into each injectors, or take to the mechanics and do some
fuel pressure test ! There are many variable for the miss firing problem. Best way is to start from something
easy and work you way up :)
Hope this helps good luck!
cheers budd!
ive decided to take it to the mechanics and gonna let let them sort it out, rather it get done right lol
ill let you all no how it geos :P
Maybe i missed something but this sounds like textbook coil failure. Time to replace the old OEM ones?
hey mate, yea its funni hey because i drove the car last nite and tested it out here and there and i had next to no missfires, i have it booked in at the mechanics teusday were i am geting a fair bit of work done to the girl so ill let you guys no what happens
Cool, still think it could be your coilpacks failing. Thats the hey mine were like. on and off on the top end.
mmmm yea but i sussed them all out and they lookded ok ?
anyway i told the mech to just sort it out and let me no wats the go i have a sussy feeling like you said its one or more of the coils though!
ya thats the thing though, they tested out ok, resistance was fine, but when i put some splitfires in there, it was night and day. if you got a friend with new ones, try it out if the mechanic doesn't clean up the problem.
mmm will do man
its a shme splitfires are so expensive otherwise i would not hesitate to buy them lol
must have been a pretty epic gap there to create that problem ive known of plenty of rbs with gaps all over the place and still ran ok. lucky it wasnt the coils. not such a big deal anymore anyway as theres a bunch of 3rd party rb coils coming out of china for half the price of oem or splitfires, with 99.99% identical performance
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
