My mechanic is not sure where to tap the vacuum of my Boost controller because the closer lines to the turbo are in metal and he don't want to cut these. He said it's better to have them the closer you can from the turbos.
Any thought??
Would this Tutorial for RB20DET work the same for the RB26 ??
http://forums.gtrcanada.com/gts-tech/t-how...ighlight=profec
Also,
Any thought??
Also,
I broke my valve unit harness on my profec2 and I can't find which wire goes where.
So, If you take the back of the unit in front of you. you will find the power harness and the vacuum to your left. Which wire is on the extreme right? white or green ?
Thanks a lot!!!
https://www.sau.com.au/forums/topic/320819-where-do-i-tap-my-profec2-on-rb26/
HIJACK!
I have realised that my bnr32 doesnt have the solenoid! Its been taken out and the two lines to it plugged up... Could definately be a reason it feels down on power - but my question is should I buy an original solenoid and put it in or just replace the original unit with a profec B???
Before someone makes comment, I do know that I wont be able to adjust the boost via a factory item (not really what I want at this stage anyway but will in the future).
u sure u dont have a boost tap of some sort controlling boost pressure?
sometimes there hidden or cable tied somewhere hard to see, have abit of a look around, especialy on the turbo side...
Edited by SiR_RB
HIJACK!
wellyou allready have the profec B, so you may aswell put that in now and just get the boost set to what you want it on now.then you can just turn it up latter when your ready,unless of course you want to buy a stock one,
So, i have to tap METAL LINES? there's no way to by-pass this!?
yeah you can just run all new boost lines. from the nipple on the plenum to the solenoid and then to a tee peice, from the tee to the 2 wastgate actuators,,, all new, you could take the other pipes off alltogether if you wanted. Oh and dont forget to block off the hose coming from the air connector- the dark blue pipe/hose on the diagram.
Edited by tuk32R
OK thanks for the info. I will be checking this saturday.
why do need to block of the blue hose in the diagram between the two wastegates ? mines still connected and seems to run/idle/boost perfectly !
If the blue line isnt blocked off you will have an air/vacume leak cause that joins to the inlet pipe from the airflow meter.So if im correct it will be sucking in unmetered air ,does that make sense?
the blue hose that goes into the inlet pipe between the 2 wastgates ? follow that around and it goes to the old boost control solenoid....thats not in use anymore so can it still get a pressure leak?
if thats the case il block it, got no probs with the car at all but might aswell do it lol
Edited by SiR_RB
Im not sure it can leak if still conected to the stock solenoid,if your cars runs fine it mustn"t leak, but it cant hurt to block it off..up to u i guess :D
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
