Cheers guys.
Found out the best price i can get from Japan for the Flag-R is roughly $6400 del
Which isnt to bad. Something alittle cheaper would be better tho.
Cheers Luke
If you want something with the remote oil canistor. also check out Tein or nismo
Nismo; they are Ohlins with nismo custom springs
http://page18.auctions.yahoo.co.jp/jp/auction/w50964703
Tein: Circuit Master : Super Racing
http://www.tein.co.jp/e/products/super_racing.html
I run the Tein in my R33 track car and they are extremely good, i think it is 30x30 adjustable (30 rebound, 30 damper) so total of 900 adjustments. However remember with alot of adjustment it means alot of track time to tune them correctly, and i have yet to find anyone that can setup these coilovers. So you will be basically on a guess and check method at the track which is very time consuming and can be costly.
Also as mention above contact Jesse and he will get you a quote direct from Ohlins in japan which i am guessing will be cheaper than the 6k quote.
Ohline DFV retail around the 2.5k mark in japan.
Quantum is another brand to check out also
http://www.qrs-j.com/
http://www.qrs-j.com/download/price/0909_nissan.pdf
They are a European brand (make suspension for ferrari etc) but also deal with jdm cars
Edited by Kaido_RR
https://www.sau.com.au/forums/topic/320858-ohlins/#findComment-5252308
Cheers guys. I'll look into those when I'm home from work later today. If I remember the quantum's have extremly high spring rates that would be shocking for our bumpy track here.
The quote on the ohlins came from Jesse, just the shocking exchange rate is killing me.
https://www.sau.com.au/forums/topic/320858-ohlins/#findComment-5252441
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
