for sale i have a complete, running RB26 out of a R32 GTR.
133 xxx kms
complete meaning from cam covers to sump,
inlet and exhaust side,
adjustable cam gears
has R33 Vspec turbos with braided lines
all piping included
dump pipes
front pipes
will basically be a drop in and turn key affair.(will need ecu,loom if going into something other than a GTR).
can be seen and heard running, will not be taken out of car until a sale is confirmed.
only removing due to an upgrade.
asking $4500
contact me via PM
https://www.sau.com.au/forums/topic/320872-rb26/
  • 1 month later...
