for sale i have a complete, running RB26 out of a R32 GTR.
133 xxx kms
complete meaning from cam covers to sump,
inlet and exhaust side,
adjustable cam gears
has R33 Vspec turbos with braided lines
all piping included
dump pipes
front pipes
will basically be a drop in and turn key affair.(will need ecu,loom if going into something other than a GTR).
can be seen and heard running, will not be taken out of car until a sale is confirmed.
only removing due to an upgrade.
asking $4500
contact me via PM
https://www.sau.com.au/forums/topic/320872-rb26/
  • 1 month later...
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
