Hi Guys/Gals,
As of the other day my R33 GTR is not making hardly any boost and is instead "stuttering" once its go past vacuum and onto boost.
here is a video:
I have cleaned the AFM's and also changed the fuel filter just incase. still goes like crap. before i hit boost the car is fine. no problems with normal driving. but once on boost it doesnt go anywhere.
When i took off one of the pod filters to clean the AFM there was a fair amount of oil film around the intake piping.... but only on one pipe... which i guess could be oil seal on one of my turbo's??
the car has the following:
Power FC
HKS priest Exhaust
K&N oil catch can setup
700CC injectors
Garret 2860-7 turbo's
Splitfire coilpacks
Im thinking i might clean out the Catch can (if i can figure out how to lol its a chrome K&N catch can with 2 breathers ontop) to see if its because its full
Any other suggestions?
Many thanks,
Elliott
https://www.sau.com.au/forums/topic/321085-turbo-stuttering-oil-in-piping/
check all piping
any smoke?
Blocked cat perhaps
I checked all piping and hose clamps etc all tight.
No smoke at all apart from normal unburnt fuel lol
a blocked cat could cause oil to be in the intake pipe? Cus I have been noticing a slight cat type noise as if the insides are losening.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
