  • Replies 150
MMMMmmmm, IT appears that i may have left a date off this.... Yet everyone appears to know when it is on:) ooppppsss. It was the 19th of june that i meant. Did anyone think different??
What are you on? lol
Awe...no e-tag.
sorry i a newb...can we pay cash?
Most of the M-something motorways have a site you can go to, for instance the m7 is something like roam.com.au. You set up an account online and have it just for that day, and it deducts it from a credit card.
