im in for this thing ill bring my stagea out and meet some people this will be my first sau evant is exciting
Dude, I'll be working out a time that us south people should meet at APR Maccas, I'll make a post in the NSW section to get us all together at the same time. Will be good, good to see stags too :)
  • Replies 150
Maybe not this time round, Justin. I know we met last year up there; but I've been asked to help another member to look over an R34 that he's interested in this Sat morning.
If that falls through, then yes, I'll come for a drive; with tickets in hand.
Or maybe, :) someone can continue to sell Cinema Tickets for us up there and get back to me later that day eh?
list thus far
cpd
pbk1776
nismo86
doubleoverhead
dave074
08r3308
warlord
tbag
TKR
dori34
wanderer
series 6 RX7
Juz
Q9tran
SIRRB
long3
sargeRX8
gTI
Evo9
R33
35???
figjam
Goodo
me
Not to bad thus far. Have over 20 cars if all shows that says they will. but i not worried. I have done the run with 3 acrs before:) See you soon
i think i've seen ur 32 around is it parked on the street ? i think it was white near cabra rd
who:? me?
my one havn't been on the road for awhile now! been in the workshop!
p.s its black (looks very standard too) :bunny:
Me and the missus may be going, not 100% sure as my sisters birthday is also on the same day, but it doesn't start until late. :) So it should be fine
Will be at Hungry Jacks on Cabramatta Road if Longz and other people are meeting there before heading off.
Q9TRAN, are you Christy's bf? Glad to see your R32 back on the road :D
Everyone still going if the weather. Is like today??
Still worth it, if only to buy your "R32 GT-R 21st Birthday" Cinema Tickets from me :D
If it's wet, I'll be in my Silver XT Forester + new SAU shirt. :(
If you're coming back down Mac Pass under brakes, with watercourses coming across the road, try to use gears rather than heat up your rotors = hint-hint... :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
