Here's a weird one.
My r34 had a miss at several points between 4 and 5 grand under load. car has 68000 kms on it so i replaced the plugs with new iridium ones which seemed to fix it.
went on a trip to melbourne and... went fine down there but while there it did the same (no maybe similar). replaced the fuel filter to be sure but no change.
what it does now is fart around at high revs (over 5k). it spits and farts (i'm good with tech stuff) at high revs/loads and shits me right off. it got gradually worse so that now when overtaking I never use second (whereas before I would use it it to kick me from 90 to 120 when behind a gobbler) i only use 3rd. even in that gear i don't like revving it too much much cos above 4500 it gets that old miss again.
I am starting to think it's possibly heat related cos it's mainly happened on hot days after a fair amount of driving and earlier today i went for a drive and it didn't happen at all.
it sucks cos i feel like i have an engine that can only handle 4000 rpm..
I'm thinking coils but surely these suckers should last longer than 70k ???
any thoughts? (other than get your shit together you blubbering fool...) :hellpisd:
https://www.sau.com.au/forums/topic/32123-spark/
my R32 did that and found out that the 6th plug tip was almost burnt off due to lean mixtures. i installed a air/fuel ratio gauge in my car after that happened. when the car hits 5 grand the power dies off completly. it still accelerates but it has no power behind it.. i installed a 500hp fuel pump and changed the fuel filter and that still didn't do the trick... now i'm thinking it could be the fuel pressure regulator. anyone got any thoughts on it?
getting back to your prob. have a look at number 6 plug and see what the go is.
https://www.sau.com.au/forums/topic/32123-spark/#findComment-645492
Here's a weird one.
Had the same problem with mine ,took the plugs out regaped them to 0.8 .
I suspected the coil packs as well so I wrapped insulating tape around the stem of each pack, so if they were arcing across to the cylinder head it would stop them.
Anyway whatever the problem was plugs or coils it has fixed the problem.
I also took my Turbosmart BOV of the car and put the standard one back.The car would never run right with the Turbosmart BOV on,runs like a dream now.
https://www.sau.com.au/forums/topic/32123-spark/#findComment-645522
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
