Guys,
Selling my racing seats... Drivers side barely used... passenger side never installed. Come with adaptor plates for rails etc.
http://members.optusnet.com.au/japimports/interior.htm
if u have a large waist then these arent for u :)
not something ud really want to ship interstae either cause i'd say at a guess they wouldnt be cheap to ship.
https://www.sau.com.au/forums/topic/32173-pair-of-obx-racing-seats-melb/
Unrelated to this sale.
Neil.
and YES gordon i do... i just wanted to put some GTR seats in instead :rofl:
just for that... :zap:
mattyb - im about a 34 waist if thats anything to go buy and still have some room... they fit really snug tho and feels great when cornering.
smooth - i probably should have got it engineered but didnt bother :) i used the stock rail for the drivers seat but had to weld a few extra bits on to make it fit to my liking.
im pretty sure u just need to modify them... i didnt know how so i just pulled apart the sotckies which was dumb cause now i dont have a drivers seat to put back in lol
autobarn sell similar ones but not this model... the fatter not as hugging ones so they should know how i spose.
lmao @ note i found on josies :P
she wasnt impressed :)
no idea on rails... i have a set of recaro rails here but they are just a little off and need holes drilled in em to fit...
will check down at autobarn and see what they say.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
