there are lots of things that could be causing it. injectors leaking, fuel pressure regulator not holding the correct pressure (could be an issue with vacuum/boost leaks), coolant temp sender, any other error codes which could be putting you into safety maps, o2's etc. if you have access to Consult or Datascan then that can help diagnose any sensors that might be causing the issues. i wouldn't be tuning it until you've made sure you don't have any other issues.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
