Try here: Skyline GTS-T Grill Badge $25 - http://www.justjap.com/parts_in_stock_new.htm
Or here: R33 SII bonnet badge $45 - http://www.justjap.com/parts_in_stock_new4.htm
Not sure of who in Melbourne has them though...
https://www.sau.com.au/forums/topic/32204-another-violation/#findComment-647066
Don't park in the city EVER if u value your skyline badging. There are regular culprits going around. Mine got badged their once, and it cost me about $70 to replace the GT badges with new ones. They stole my 'S' too, but i didn't want it anyhow, lol.. but still.
https://www.sau.com.au/forums/topic/32204-another-violation/#findComment-649544
nissan wants more? damn, i don't think these little ****ers how much it actually costs to fit another of these badges..
Badging a commodore or falcon costs hardly anything and they're easily to find another, but a skyline it costs a fair whack, and it looks crap without them unfortunately.
https://www.sau.com.au/forums/topic/32204-another-violation/#findComment-649646
http://www.justjap.com/parts_in_stock_new3.htm <-- those $49 ones say they are for "Skyline GTR R32/R33 guard badges" maybe the GTST ones are cheaper??? - shoot them an email or give them a buzz!
I know you are talking about the GT badges!
Perhaps the thieves DO know the value and THAT'S why they rip them...pri(ks
https://www.sau.com.au/forums/topic/32204-another-violation/#findComment-649808
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
