I'm looking to upgrade the fuel system with 2 x bosch pumps and a surge tank.
To keep it legal the fuel system cant be mounted in the boot, plus id like to keep the boot space. With the limited room underneath how have people over come this problem?
PS: I have a 32 GTST.
Edited by Alf
https://www.sau.com.au/forums/topic/322054-undercar-surge-tank-pumps/
Autosport (I think its brads R32 gtr) had this set up.. looks very neat.
Speak to EFI performance. Pierburg external fuel pump. No need for surge tank.
A pump alone wont be enough when the fuel in the tank moves away from the intank pump, thats why a surge tank is needed.
I'm using an 023 intank.
Edited by Alf
Yes I know what a surge tank is for. I understand what you are saying but I have been assured you wont need one with this setup.
Here is a 'quote' from an email from Rick at EFI
"We recommend you look into an extra external pump we use and recommend (pier berg) high volume fuel pumps which are a draw and push pump capable of 350L per minute @ 3bar where the bosch 044 external is only a push pump and with its expensive fittings ect they are rated at only 200L per min @ 5bar."
"We have used these pumps on over 40cars now and are really taking off, they can be used with C16, methanol and are also E85 user friendly where the bosch pumps are not."
Like i said, I reccommend speaking to the EFI guys. They are really helpful and great to deal with.
Any love for the PierBurg?
Edited by RBceffy25
Forgive me if I'm wrong, but a draw/push pump is self priming? It can recover from the air in the fuel lines quicker?
I still can't see how this is supposed to replace a surge tank.
The system on steves gtr was built and designed by myself from steves guidline of everything in one unit under the car.
The current ones I'm using on my GTRs have individual chambers supplying the pumps and are foam filled to settle the fuel a bit more.
I rather use them with dash fittings as opposed to barb tails and clamps.
They work well and are realativly inexpensive.
Ive seen a few jap gtr's with a similar design is it based on a sard item?
It's not based on a sard item.
I jacked my car up, saw a large space near the driveshaft with nothing there, went to autosport and told them what to do and what I wanted. Greg and brad did the rest. I can't weld to save my life.
I wouldVe liked it to be tucked up further but then it wouldn't be as big. Flow was a concern as Brad and Greg figured out the tank had to be over 4L for the pumps I'm using.
The timing worked out great, they fitted all the rest of the fuel setup and the motor aswel. I always recommend them.
they dont say anywhere that the dont require the use of a surge tank and all pumps have to pull push as the fuel doesnt get gravity feed into them.
thats a perfect spot stevo. for a little more detail its the same on the GTSt and the spot is on the drivers side just in front of the back wheel. basically under the rear seat.
Any idea on prices to get one made up (to suit an R32 GTR)?
My mate and I made one the same as the process west unit for his xr6 turbz. Except instead of a billet tank welded down I just folded it up out of 3mm ally and welded it down to a lasercut plate. Turned out much the same and saved the expense. No need for a flashy unit when its tucked under the car and getting dirty constantly.
Edited by r33_racer
Any idea on what one of these surge tanks cost?? Was it a custom one off job or an off the shelf item?
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
