I'm confused..... Cop was flying down road with lights going (obviously going to attend to a problem), car pulls out and makes him lock up and he decides this is more important than initial problem???????????????????
after interpreting his post and converting it to english it looks like the cop was driving along (apparently very fast) without the lights on, locked up to avoid hitting OP then put lights on and pulled him/her(?) over.
Guys stop this conversation as we cannot understand the phrase he's trying to said! I read this as he was pulling off may be drift through the ocean reef t junction and the cops at the back find this intresting and they want to give it a try, so the drift it as well. Point is to show whose the daddy. Anyway we need FBI to investigate what he's trying to say!
um...WHAT?
meanwhile, how do cops lock up their wheels? I'm pretty sure it would be an FG or VE they are driving with standard ABS, so at worse they dropped the anchors and broke very hard.
I'm with everyone on the bad pulling out of traffic 101. Maybe the cop cut you some slack because you were on your P's and a more experienced driver should know better, which I think makes sense. Just don't end up like those tosser P platers on the road that think they are the best drivers around because they've played gran turismo for 4 years.
I agree. You need to play need 4 speed to be a good driver!!!! :-P
So you're allowed to be a shit driver if you only just got your license, but if your off your Ps you need to be pro ?
That's a shit excuse.
Next.
Next.
No, but inexperienced drivers should be given some slack. If you're an L-plater are you expected to know how to drive straight away? Or are you allowed to get better with practice? The purpose of P-Plates is to show that you are an inexperienced driver who might not react as you would expect in every situation.
L platers should be listening to their instructor...so they're never really put in a situation where they can misjudge a T-Junction and cut off a cop car.
L Platers arent full qualified drivers so yes, some slack should be expected, hut one you have your license, Ps or not, you should know how to drive.
P-platers are not full qualified drivers either. Something as simple as misjudging a gap should not be condemned as inability to drive, rather as a lack of experience. Do it once and you won't do it again. Hence experience.
^ +1
Edited by That_timothy
P
Provisional
Doesnt mean not qualified...it means you're a newbie, so behave. Ie you're under more restrictions and on a "good behavior bond" kind of thing.
Over East, you get 6 demerit points, are not allowed passengers, cannot drive between 00:00 - 05:00 (unless directly to/from a workplace), and cannot drive high powered cars (boosted 4/6 cyl, 8cyl).
Edited by Nic_A31
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
