1992 R32 GTST
excellent Silver paint
HKS Hyper turbo back exhaust with high flow cat
Pioneer CD player
aftermarket front and rear speakers (Pioneer rears, and JL front)
Pioneer amp
rego 11/04
GTR rear wing
rear pods
Autometer (silver-faced) boost gauge
serviced every 5000kms
Upgraded Bosch fuel pump.
Repadded front drivers seat.
Garaged
115,000kms
Pics are available at:
http://groups.msn.com/paul17maher/shoebox.msnw?Page=1
Price: $15000
Contact: 0412591369
Willing to consider a trade........
https://www.sau.com.au/forums/topic/32251-wanted-r32-gtst/#findComment-659563
'92 R32 GTS4
101,000kms
Bar & plate Hybrid FMIC
17 inch Work equip wheels
Brand new Kuhmo ectsa supra tyres
R34 turbo @ 10psi
R33 GTR Fuel pump
3 inch exhaust from dump pipe
GTR V spec II shocks
Lowered King Springs
HKS EBC
HKS sequential BOV
HKS turbo timer
Autometer boost guage
Polished engine
Nismo gear knob
Airfilter
Front strut bar
Tinted windows
Factory 10 Stacker CD player
Parts not fitted.
Adjustable fuel pressure reg.
SAFC1
Custom chip for ECU
Oil catch can
Stock wheels with almost new falken ziex tyres (90%+ tread),
Timing belt and water pump changed at 80,000kms.
Serviced at 5,000kms intervals if not more frequently.
$18,000 neg
https://www.sau.com.au/forums/topic/32251-wanted-r32-gtst/#findComment-659712
hey guys here are the details of my car
TOYOTA COROLLA SX 1991
Supercharged 4agze conversion with gearbox, engine mounts and all, and swapped the hubs over
(its all out of the AE101 Levin Coupe halfcut I got)
Re-worked computer 10psi,
Heavy duty TRD clutch,
HKS air filter,
2 inch exhaust system with a cannon sports muffler,
Front and rear disc brakes with new pads,
New cv joints,
Monster tacho with red shift light and boost gauge,
MOMO Sports steering wheel 13inch,
MOMO gear knob
Tinted windows,
$3000 stereo system
(pioneer 9450 headunit, sony explode 6” x 9” , pioneer 5½” splits, 12inch Rockford fosgate sub and Rockford fosgate amp, in sub box which is bolts to floor)
Lowered 2.5inchs,
15" hyperfang rims & matching spare & spare standard corolla rim,
Power steering.
Aircon (not gassed)
Good condition inside and out,
It has rego till next September so about 9 months,
The engine standard was 123kws, and now it’s at 145kws at the flywheel
It only runs on premium fuel. (I’ve only ever put in shell optimax)
I got the car in August 2003.
The conversion was only done 6 months ago,
The engine was purchased with only 82,000kms, got all receipts.
and I’ve done about 13,000km,
Serviced every 5000kms
Had a Major service done on 20/1/04[/size]
https://www.sau.com.au/forums/topic/32251-wanted-r32-gtst/#findComment-659806
I have a black r32 for sale if ur interested Dec 1992, manual, 5 puck button clutch, 3"zorst, HKS EVC, Apexi Multichecker, strutt bar, k&n filter, bov, AM fuel pump, AM fuel regulator...but 2 air vents on the dash need to be replaced cus my girlfriend broke them. also comes with a t4/t3 hybrid turbo that needs a rebuild that you can chuck in at a later date, i was told it supports about 500hp. if ur interested email me for pics i have a few of them. [email protected]
https://www.sau.com.au/forums/topic/32251-wanted-r32-gtst/#findComment-665591
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
