I have the following for sale suit R33 GTST:
Hybrid Style Front mount intercooler kit. 300x600x80mm
Excellent condition with all parts required to fit to an R33 or C34 stagea
$330
R34 GT-T sidemount Intercooler. $100
3.5in stainless Jap exhaust. Has 2 resonators and 1 large rear muffler. Excellent flow without being too loud. $400
Floor mats. 2 sets to choose from. $90 per set
Stock airbox with mounts and snorkel. Excellent condition with HKS panel filter. Clear those defects. $110
All parts are in Campbelltown in Sydney
Edited by too_much_boost
https://www.sau.com.au/forums/topic/322737-r33-gtst-parts/
Hey mate, got any pics of the intercooler fitted?
Any modifications required to make it fit?
Ive got the same cooler. I didn't fit it in but it requires you to make a hole on the driver side to run the piping back.
Would you sell the piping from the IC? I need the pipe with the mounting bracket.
https://www.sau.com.au/forums/topic/322737-r33-gtst-parts/#findComment-5264861
