For Sale:
1. RB25DET motor - 160psi Compression across all. 99,000kms. Excellent Condition. no TB, Fuel rail, aircon, PS pump, or CAS. Will come with Standard injectors and Coil packs.
$1000. Free postage to Brisbane, but you'll have to pick it up from a Depo.
2. Split Dump \ Front Pipe to suit Garrett GT30r Rear housing Bolt Pattern all the way to the cat.
Made 315rwkw on 18psi
3inch + Extra Wastegate Split
Stainless, custom made.
Will fit any RB25DET with Factory Exhaust Manifold.
$400 pp
Pics:
3. Garrett 0.63 IW Rear Housing for GT30r Turbos
No cracks
Excellent condition. Just a bit dirty in the pics.
Made 700nm of Torque
Car was super responsive
$350 PP.
Pics:
My Email: [email protected]
My Phone: 0439 336 407
Just shoot me an SMS and I will call you if you want to talk about it.
Edited by The Mafia
None at all actually. was running 20psi, and it seemed stable all the way to the limiter.
The boost was at 18psi when I made 314rwkw. I have a boost plot somewhere.
Was a little 8psi actuator.
Boost was set to come on gradually because it was awesome with traction loss lol.
This plot was also before I adjusted the tune and fuel pump to later make 314rwkw.
Edited by The Mafia
Pretty interested in the turbo. What supporting mods did you have to produce that amount of power? Ive got everything modded on my car except engine internals. Would my car benefit with this turbo? Any shaft play? Would I just have to remove my old turbo and bolt this one on(direct replacement)? Cheers.
  • 3 weeks later...
sorry if this is a low ball, but would you be able to do 320 shipped to the US?
im not so keen on pices/sshipping, and all that.
PM me so we can work something out! I am trying to recreate your turbo as it stands lol
hey mate, $320 for the lot or the rear housing?
Thats pretty good for the rear housing alone. Make a better offer and I will consider.
To the rest - Still for sale :)
Edited by The Mafia
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
