Hey All,
I'm looking to upgrade my R32 GTR brakes to R33 GTR Bremobo's all round.
I'm looking for calipers and rotors which are all in good nick!
Any help would be appreciated, if you know who's selling some let me know, and if your selling some hit me up!
PM me, or gimme a buzz on 0434304509 - Jay.
I'm keen on getting some as soon as possible, so if you have let me know!
Cheers Guys!
Jay
Edited by Oo-SKYLINE-oO
https://www.sau.com.au/forums/topic/323595-wtb-r33-gtr-brembo-brakes/
Don't know how different the mounts are from an R34 GTR, but will soon have a full set of original Brembo rotors/calipers/pads off my R34 GTR Nur (front and rear).
Fronts off already, waiting for rears to arrive. Plan is to sell them once my changeover is complete.
Rotors need machining to tidy up the outer lip and refacing (would never been done after 50,000kms) - but otherwise full OEM kit excl. bolts.
Hey All,
Cheers Guys!
Jay
I HAVE A SET OF R33 BREMBO ROTORS BRAND NEW PART NO RDAA7701G. THESE ARE SLOTTED DIMPLED AND NEW STILL IN BOX AND ARE A MATCHED PAIR. PAID $640 WILL SELL FOR $450 PLUS SHIPPING CHEERS BRAD
Hey Brad,
By a 'set' do you mean Four rotors?
- 2 Front
- 2 Rear
Cheers
Jay
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
