hi guys
can anyone tell me what type of turbo the rb25det engines have? is it a t3 as i'm told? the reason i am asking is cause i plan to upgrade it, should i have it hi flowed? or just replace the entire unit with a t3/t4? has anyone done this before? and if so what hp gains should i expect?
thanx
https://www.sau.com.au/forums/topic/32367-rb25-turbo-specs/
I would think a high flow would easily achieve the sort of figures you are chasing:) if it is done properly.  I had an easy 200rwkw (around 350 odd bhp) with the stock turbo at 12.5lbs.
what other mods do you have?
the mods that i have so far but have not installed yet are :-
1 3" cat back exhaust
2 field fuel controller, (does the same job as the apexi safc)
3 blitz dsbc boost controller
4 z32 afm
5 bosch rising rate fuel pressure regulator
suggestions?
https://www.sau.com.au/forums/topic/32367-rb25-turbo-specs/#findComment-649326
just a question for you, sorry about it beign off topic, but i hope youi can help..
when i got my car there was a cable comming from the computer with a switch on it.. either "boxer" or "normal". it said Field above it... is this what you have? what does it do.
i would love any feedback as i have had the car for 6months and not known what this does.
thanks
https://www.sau.com.au/forums/topic/32367-rb25-turbo-specs/#findComment-649552
4  z32 afm
suggestions?
Intercooler will help alot
Upgrade your fuel pump
think about clutch, stock one can die at as little as 200rwkw
Full management would be a much better option than a fuel controller - controlling ignition is pretty important.
Dump and front pipe, you need to get all the restrictions out of the exhaust side, and get rid of the cat too (as long as you wont get in trouble:))
Also, for the power figure you are looking at, it could be a bit risky to run the stock injectors. I know alot of people do still use them, albeit stretched by the fuel pressure reg, but you run a real risk of detonation, and a set of injectors costs alot less than a full rebuild.
should get you there.
Anybody else think of anything I missed?
https://www.sau.com.au/forums/topic/32367-rb25-turbo-specs/#findComment-649719
i have enquired about a hiflow at GCG, i was quoted $1950 for Stage 1.
for that money, id be seriously considering a low km HKS 2530.
a brand new 2530 will cost you around $2500 delivered from www.greenline.jp and it'll include all the necessary bits and pieces and probably a HKS sticker too :D
https://www.sau.com.au/forums/topic/32367-rb25-turbo-specs/#findComment-650263
thanks
the field controller i have is a unit in which you have to install into the wiring loom,, its a separate unit with adjustments and a digital display that reads your 1/4 ille times, your true speed, your true rpm, your a/f ratio and your tranny shift points (if its auto) and a host of other things,, the unit is marked "field hyper-r boxer series", is this whats on the other end of youe cable?
https://www.sau.com.au/forums/topic/32367-rb25-turbo-specs/#findComment-650625
intercooler----i have at my disposal a toyota supra fmic,, its not as big nor efficient as the gtr one but i guess it will have to work till i can get a real fmic
fuel pump-------i have a toyota twin turbo fuel pump
clutch-----full act clutch and pressure plate (6 puck copper/ceramic)
management-----i am trying to get my hands on a power fc
dump pipe-----this depends on what turbo i use,, right now its stock, which leads me to my first question,, that type of turbo is this? is it a t3? is it a t25? what is it? i have no idea.
injectors------ havent yet thought about these,, but i will see if i can get my hands on some 550cc's,, thanx for the replies guys and could anyone please tell me what type of turbo i have? its a stock series 1 r33 rb25det thanx
https://www.sau.com.au/forums/topic/32367-rb25-turbo-specs/#findComment-650655
cat---- as for this,,, hmmmm well lets say that i havent had one of those for years now lol
https://www.sau.com.au/forums/topic/32367-rb25-turbo-specs/#findComment-650658
the stock nissan turbo is neither a T25 or a T3, its nissans own.
You can get bolt on dump and front pipes from manufacturers such as HKS, that seperate the wastegate and turbine outlet pipes. fortuneately the nissan outlet is the same as a GT25 turbo, so no probs with compatability if you do go a GT2530 - which would be my first option before a high flow, unless of course you are doing your own?
Something else that wouldnt hurt, a good pod, but make sure you have a partition and CAI. The partition and CAI are really easy and cheap mods and make a world of difference on and off boost when the days start warming up.
https://www.sau.com.au/forums/topic/32367-rb25-turbo-specs/#findComment-650759
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
