  • Replies 54
Steve,
Top Result :D
Guys,
I made the change from a NISMO 80mm performance system to a HKS Ti Drag System, and managed to dyno the before and after. I was running the stock turbine, and the results can be seen over on the www.gtr.co.uk forums.
Some details of the exhaust system here
and the dyno graphs are here
Well I just got my car back from being rebuilt and it seems louder and more throaty than before (even though it shouldnt, its probably because I havent driven it for a long time :D ) We did a before and after dyno when I fitted just the cat back section of my N1 and I gained in the region on 18kw@wheels all up this was the first mod I did and I'm sure all the mods after have gained more for it :( Just hope I dont get pulled over cause then I will have to put a resonator on the system.
the apex dual n1 it theebest exhast for guaranteed Performance there was even a dyno graph produced by apex to back this up . but they are really really loud.
my sr followed the advice of this thread I ahve a 3 split dump 3" mandrel front pipe hiflow 3" cat to a hybrid hap based exhasut I get boost pressure from 2100 rpm full boost from 3200 and on the dyno chart from the factory they reckoned full boost from 4100 rpm. bizzare but I love it . thanks for the tips steve the advice was followed .
meggala
sounds good is there a link to this review? :)
meggala
Here you go boys;
"The N1 Duel are designed to retain the same peak HP of the single N-1 while improving mid range torque.N-1 Dual Mufflers are a variant of the popular single-tip N-1 Series Mufflers. The N-1 Dual piping splits into two smaller diameter pipes just after the catalytic converter and flow into a pair of 120mm canisters. The canisters are polished off with aggressive 90mm tips. The use of smaller piping diameter helps retain more mid-range torque. The Dual N-1 does not sacrifice peak horsepower because the dual pipes can handle more exhaust gas volume. Piping is treated with high-temperature titanium particle coating, and the canisters and tips are constructed of polished SUS 304 stainless steel."
Im gona be getting this done :wassup:
yeah, the general knowledge is pretty much 3" pipe the whole way back with as little other restrictions such as cats in the way. i have an 83 car now so i can have just 3" all the way back and then muffler. i had stock dump and front pipe and stock old little cat in there, got the dump and front made 3' and the cat removed, picked up a bit more top end a bit of response, havent dynoed it after it though for any hard proof of difference.
13.58 is correct with pfc base maps @ 12psi, Not bad a!. Considering i had my 2 12'' subs in the car as well. :)
should be a very low 13 this weekend :aroused:
WLD747 dude your best time in your sig is 13.58 right, but arent you running PowerFC base maps ?
dude, not bad, thats ****ING BAD!!! you idiot your gunna kill your car, STOP DRIVING ON THE FARKEN POWERFC BASE MAPS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
!!!!!!!!!!!!!!!!!!!!1 they are made for seeing that the car starts n idles, NOT FOR DRIVING ON AT ALL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
RELAX, DJ_L3ThAL Its gona go for a dyno tune this weekend. :D Then i should pull a good 1/4 mile. :) . I just havent had any free time cause of work and this weekend i will. :)
:D if you go calder i'll tag along. Maybe we should do a skyline australia calder thing. :wassup:
i still dont believe ANYONE can pull a 13.58 on a powerfc base map with the mods you have bro, im taking mine to calder soon a got a few more mods than you and i rekon i'd struggle to get low 13s
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
