Hey guys,
I recently just bought a 12" Alpine Type S sub (SWS-1223D)
Now, I need to buy an amp for it.
Its rated at
900W peak and 300W RMS
Impedance: 2ohms + 2ohms
So, being a noob and all, I needa know what exactly I need to look for in an amp. All I know so far is to look for a monoblock amp. What sort of power should I be looking for that would be suitable for this sub?
A friend of mine said its better to overpower your sub rather than underpower it?
Any help would be much appreciated
https://www.sau.com.au/forums/topic/323805-amplifier-selection/
I've got that same sub in my complete Alpine R series set up but im running it all on the one amp crossed over, the amp im using is MRP-F600 which is 1320W max.
Hope that info is at all helpful, but im sure that people with a lot more experience will give you more info on a proper mono amp suggestion, just thought the 1320W Max spec would help with an indication of how overpowering is what they did with mine.
are you brand loyal ?
you don't need a mono, you can use a 1,2,4 channel amp depending on the amps load handling, I use 4 channel bridged x2 into a 1 ohm load on my subs but only to reuse some old stuff I had lying around until sponsors supply the amps in my car
too much power is better then not enough its called "headroom" more headroom less distortion, in the right sub box of course
but some amps can hammer your charging system bad, so you need to take that into account as well ?
do you like music loud ?
what kind of music?
do you plan on competing in SQ or SQL, testing ? sound offs ?
do you want a show off amp or hidden?
what kinda head unit do you have ? does it have outputs for sub x over?
to tell you the right thing, you have to take this and more into consideration to make the right decision ?
what kind of music?
yea loud music is nice, well Id like the option of having it fairly loud.
I listen to pretty much everything from heavy metal to rnb to trance.
I dont plan on entering competitions, this is just for my enjoyment :thumbsup:
not too fussed about showing the amp off, pretty sure its just gona be attached to a box sitting in my boot
I have an alpine CDA 9886, http://support.alpine-usa.com/products/doc...OM_CDA-9886.PDF thats the owners manual, it has an extra sub output thingo.
lastly, I typically stick more known brands, but dunno if Id say Im loyal to any in particular
a reasonable brand 600w mono amp should do for your type-s. But if you can, id suggest you get something around 1000w and run it around 400w so your not stressing the amp so much plus you can always upgrade your sub in the future and the amp will still be able to handle the new one giving that its only a little bit more powerfull.
I dont plan on entering competitions, this is just for my enjoyment :P
what car is it going in ?
how much room do you care to waste, spare tyre intacted still ?
going in an r33 so the boot space is already pretty limited lol
already got the sub and box and thats gonna take up a fair chunk of the space. I was told I can mount another amp on top of my other one which is near the battery or I can just put it on the back of the box.
I couldnt edit this so Ill just add onto it here...
forgot to mention that the spare wheel is still there and will stay, mainly cause my dad is a bit of a safety nut and will complain if I take it out lol
he's still confused as to why I had to go buy a skyline hoon-mobil haha
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
