Thought it was time for us to hit the track and burn some rubber. It also gives us a chance to put our sticker on the side to promote the business and have some fun.
I got the car in feb this year as a pretty clean car would have made a good cheap first car.
Most of the parts for it will be what we have around the shop custom made or our of china.
The car will receive
Gtr injectors
Nistune board
custom DMD high mount manifold heat wraped
china 50mm gate
Holset HX35 turbo rebuild kit done by us
custom 3 inch exhaust straight out exiting at side near rear passenger door
china cooler
custom cooler piping
blitz bov
DMD custom AFM good for 1000rwhp
4 inch inlet pipe
custom dash with gauges
stripped interior and sound deadning
cams weld in cage done by us
r32 gtst front brakes
DBA 4000 rotors
hawk semi comp pads
hydraulic handbrake
s13 front suspension conversion
s13 coilovers of some type
DMD spec oil cooler
Ford teritory re drilled rims to 4 stud and prob drift tek's what ever is cheap
just Jap bucket seat
it has an LSD
DMD custom MFD display with touch screen with every engine parameter
standard high comp RB30 220,000km on the clock
turbosmart boost tee
xtreem clutch
cryo treated gearbox
just Jap r31 front lip
bonnet pins
battery in boot
gtr steering rack modified for more throw to get more steering angle
I'm sure there will be something I missed which I will add later.
The car is an auto at the min and I will tune it with it as I want to run it at Calder and see what it runs. We are putting bets on how many runs it will take and how quick the car will go.
See the pics of where we are up to have got busy in the last week with a truck engine and a RB26 conversion in a R32 gtst.
We are also planing to maybe if the rb30 goes to put in a vh45de with twin Holset hx35's and a nistune
We also want to try have this car so we can use it fir track an other motorsport like deca or targa tas to give that a bash.
That's right mate this will have the smallest budget I have planed on to build a car it will be hitting the track with most of them parts put on in stages.
Gtr resistor all wired in last night just waiting foe the ecu to get back from nistune and find time to make the intake pipe and tune it
I was quite impressed on how the gtr steering wheel came up. It was out of the gtr I am building up but someone had pulled the leather off must have been worn our and painted it black. All the paint was cracked and stuffed so I sanded it all off.
Came off real easy and now has that swede type feel to it now quite grippy
Hey mate yep keeping them alive parts are cheap so perfect for the drift pig I say. Tossing up between running the 25 head I have one day but I think the single cam will do enough tyre burning with that turbo on it.
I have a smashed white car sitting outside for parts donor if need be.
I have also changed my mind on the gear box I have a spare gtr box that I'll mod up for rwd and weld up a custom tailshaft.
Coilovers will be on there way sometime next week I would say
Got the car up an running last night and after some stuffing around with the battery was dead flat got it going.
Here is two dyno sheets the first was with it NA straight out the headersand the second was the base play around last night at 11pm was only 9psi and round 11's pretty rich but didn't spend alot of time from the base tune I had for it.
it ramps up hard with the holset and hits the gate early around 2800 rpm and then flat lines. The auto and bald tires wouldn't be helping with making power so should have been a little more with good tires and a manual.
I will crank it up to 18psi tune it then hit Calder to see what it runs down the 1/4.
Pull the gearbox out and get it drift ready.
All set to tune it tonight after I've finished what I have to do for the day. I did some numbers and the auto looks to be loosing closer to 40% of the power so at the engine power with a manual it should be closer to 200rwkw rather then the 150 it's making now
A few issue last night when I turned up the boost. I thought I might have gotten away without yapping the plugs down and replacing the leads coil dizzy cap and rotor button I was wrong tuned it up and blowing out the spark. Will head down tomorrow morning and get some new gear while getting some oil filters for a few jobs I've got.
Run into a few more issues on the weekend managed to find an hour to get it on the dyno late sat night around 10pm. The inlet manifold gasket didn't like 18psi and made itself a nice little vac leak ouldnt expect much more from a 21 year old gasket and 230,000 km with a big turbo and some nice boost.
Looks like I will grab a full gasket set and do the head at the same time. Will also look to stick the die grinder in and give the head a port job and stick a bump stick in.
The auto realy doesn't like the boost either so need to ditch that as well
  • 3 weeks later...
  • 4 weeks later...
  • 1 month later...
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
