i have a strange problem
when my car is first driven, the clutch and feel normal. there is freeplay at the top of the peddle point and engagement is where it should be, around the middle or just below.
however when it gets warm, or a few laps on it starts to change and peddle looses its free play and engagement point gets up higher a bit. peddle doesnt feel as nice to use and im worried theres pressure on the pressure plate all the time.
ive found that if i crack the 8mm bleed nipple on the master then it releaves a bit of pressure and then all is perfect again... until i let the car sit for a few hours then it does it again.
suggestions?
https://www.sau.com.au/forums/topic/324198-hydraulic-clutch-issue-help/
