Hey guys,
How strict is regency for transferring rego from one state to SA plates?
Mods on the car at the moment:
POD
FMIC (uses standard SMIC piping, doesnt cut thru chassis)
HKS EVC-S (in glovebox)
Apexi Turbo timer - hooked up to handbrake?
Standard Wheels (plenty of tread)
Trust exhaust (pretty darn quiet, must have baffles galore - certainly has a couple of resonators)
Xenon Headlights
Rear Swaybar
DVD player (not earthed to handbrake)
Now, the standard airbox is going back in, front mount is staying there, boost controller and turbo timer are coming out next week and DVD is being 'legalised'....Anything else I should look out for? Or should I just polish the crap out of it, put the spoiler back on and she'll be right?
Any advice or opinions or anyone who had done this before in SA - hit me up!
Cheers
POD OK if ts secured
FMIC (uses standard SMIC piping, doesnt cut thru chassis) should b fine
HKS EVC-S (in glovebox) remove this guy
Apexi Turbo timer - hooked up to handbrake? and this guy
Standard Wheels (plenty of tread) its all good
Trust exhaust (pretty darn quiet, must have baffles galore - certainly has a couple of resonators) could go either way depending on the Db's
Xenon Headlights could go either way depending on the blueness
Rear Swaybar nfi
DVD player (not earthed to handbrake) earth it up and should b OK
Now, the standard airbox is going back in, front mount is staying there, boost controller and turbo timer are coming out next week and DVD is being 'legalised'....Anything else I should look out for? Or should I just polish the crap out of it, put the spoiler back on and she'll be right? yeah sounds good apart from the spoiler ewwww
f**king hell bro, use the search tab :)
btw; some R34's came factory with xenons so it shouldn't be a problem althought with compliance you have to switch globes, ID check won't know this.
Edited by Weezy
you just need to go to a cop shop for a number check and if there are any obvious defects, as in emissions, then they'll send u to regency..thats what happened when i bought my old 32 from melb..took it to sturt road cop shop n just had to remove some gauges and take it back to the cop shop as it was only a minor thing to do.
I purchased an R33 GTR from Vic and brought it back to SA a year or so ago.
See my thread for the story: http://www.skylinesaustralia.com/forums/In...-T-t267077.html
Remember it's an "ID inspection". Very different from say a defect inspection or import where everything needs to be stock. They basically just match the VIN, engine & reg details. An inspector looks over the car for about 5 minutes and he didn't even look in the cabin.
POD - i have too
FMIC (uses standard SMIC piping, doesnt cut thru chassis) - mine was standard
HKS EVC-S (in glovebox) - nfi
Apexi Turbo timer - hooked up to handbrake - no problem for me but I did hide it inside the steering wheel column, didn't disconnect it, but it is illegal so best to make sure they dont find it
Standard Wheels (plenty of tread) - mine were 17" in dish rims
Trust exhaust (pretty darn quiet, must have baffles galore - certainly has a couple of resonators) - mine was the loudest POS canon ever but still no problem
Xenon Headlights - i have too - I dont recall the lights even being turned on
Rear Swaybar - mines stock
DVD player (not earthed to handbrake) - I have too, not sure about earthing but they didnt check any internal wiring
Someone correct me if im wrong, but for ID checks you can only go to either Sturt Inspection Station or Regency, not just any cop shop?
if you have the car registered under your name in another state then its as easy as just changing the address :)
no krishy it's not. When my other half moved from sydney he had to go to regency have a FULL inspection befor they would issue the change over to SA plates and they told him he had to get some things fixed
If ID check are the same people who do regular regency inspections .. or even if they call 'em over cos they're not sure - yeah. I say this because I got done for my factory xenons when I last went through Regency (he called someone over cos he wasn't sure). Because they're not auto-levelling and don't have any washing function, they don't pass ADRs.
Anyway, an hour or two with a foglight wiring kit, some cutdown H7 (I think) globes, and I converted them over for the next pass through - fairly easy (.. and horrible lighting in the meantime till I put the old globes put back in)
It was for me. I've transferred two cars into SA rego (N14 SSS and R34 GTT), one from NSW and the other from Vic - both in my name interstate and was a straight transfer, I don't think they even did an ID check, just signed some papers, paid my money, changed plates - voila.
i have had mates who have brought cars from interstate and had the car registered under their name.....and they did exactly what JRM did.....dont know what happened to your other half Kellz
Regency is hit and miss.
Compliance guys took my V35 down with privacy tint and they failed it yet i see countless numbers of stags etc cruising around with it daily! Im not fussed cos at least when i re-tint it will all match nicely, but pain cos it meant i lost one day of pleasantness and the goo left behind on my windows is proving difficult for even the pros to remove.
The sturt one got closed down. When I brought my gtr back from Victoria, they told me for an ID check it was either lonsdale or regency.
Got a ceffie through there today had to get a vin stamped on the strut tower the rest was no real hassle.Car was on NSW reg.The tier 2 is really just to confirm its not stolen defected etc etc..
Why did you have to have the vin stamped on ? Did you have a sticker vin instead of a plate ?
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
