  • Replies 58
welcome to the shite umpiring cup all teams will now do paper sissers rock to decide games due to unavailability of any umpire with eyes
f**k that, how about we just scrap the games altogether and the referees can just play chess between themselves
Yeh, to be honest it probably was a red card (by FIFA's stupid rules anyway). But how about that tackle by the Ghanaian? That was a clear red card under any circumstances. Yet Timmy Cahill gets sent off for his tackle. It's ridiculous.
Disagree with you on Mcdonald, hes crap...
Imo 4-4-2, Ruki and Kennedy up front.
Haha there you go again blaming the players for the coaches faults. McDonald isn't crap, he is the best striker Australia has, and is a far better player than Mark Viduka or Harry Kewell (albeit a different sort of player). His record speaks for itself, 51 goals in 88 SPL games for Celtic. The difference between his form for the Socceroos and his form for Celtic is the fact that when he played for Celtic his coach used him in a formation that suited him, and reaped the benefits. For the Socceroos he has always played upfront by himself, which he absolutely can not do.
People seem to think that if a player is good then they can play well in any position and suit any formation, but it really isn't the case. If the coach gets the tactics right and has good man management skills, any team can beat anybody, eg. Switzerland vs Spain, Serbia vs Germany, New Zealand vs Italy... All perfect examples of the coach nailing the tactics. Don't underestimate the influence tactics and good coaching has on a game.
Edited by Hanaldo
Australia 2-1 Serbia; Germany 1-0 Ghana. Not enough for Australia to go through to the last 16 :D What a good effort though. Anyone who tries to tell me Australia can't play football, I will be pointing them to that match. Unlucky Socceroos
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
