  • Replies 58
welcome to the shite umpiring cup all teams will now do paper sissers rock to decide games due to unavailability of any umpire with eyes
f**k that, how about we just scrap the games altogether and the referees can just play chess between themselves
Yeh, to be honest it probably was a red card (by FIFA's stupid rules anyway). But how about that tackle by the Ghanaian? That was a clear red card under any circumstances. Yet Timmy Cahill gets sent off for his tackle. It's ridiculous.
Disagree with you on Mcdonald, hes crap...
Imo 4-4-2, Ruki and Kennedy up front.
Haha there you go again blaming the players for the coaches faults. McDonald isn't crap, he is the best striker Australia has, and is a far better player than Mark Viduka or Harry Kewell (albeit a different sort of player). His record speaks for itself, 51 goals in 88 SPL games for Celtic. The difference between his form for the Socceroos and his form for Celtic is the fact that when he played for Celtic his coach used him in a formation that suited him, and reaped the benefits. For the Socceroos he has always played upfront by himself, which he absolutely can not do.
People seem to think that if a player is good then they can play well in any position and suit any formation, but it really isn't the case. If the coach gets the tactics right and has good man management skills, any team can beat anybody, eg. Switzerland vs Spain, Serbia vs Germany, New Zealand vs Italy... All perfect examples of the coach nailing the tactics. Don't underestimate the influence tactics and good coaching has on a game.
Edited by Hanaldo
Australia 2-1 Serbia; Germany 1-0 Ghana. Not enough for Australia to go through to the last 16 :D What a good effort though. Anyone who tries to tell me Australia can't play football, I will be pointing them to that match. Unlucky Socceroos
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
