Bought these aproximatley a year ago but am selling the car without them. These are fantastic coilovers and for the $1600 I paid for them they are far better than alot of other stuff I have used costing alot more! They are in as new condition and I don't think you could find a better set without buying new anywhere! Will get some picks up ASAP.
Asking $1200 +$50 delivery to most places in Australia or pickup from Mill Park. Ph: Kyle on 0422089059 or PM Me!
I know this isnt what you'd want to hear, but if your desperate to sell, i can pick up tonight with $500 cash. Im also in Mill Park. 0401 682 270. Let me know
No idea if they will fit an s14, I bought them for my 32 gtst, bit on searching on ns should be able to tell you. Spring rates are 8kg front and 6kg rear. They are height adjustable, with how I had them setup they could have gone probably an inch or so lower from memory.
Pic:
http://www.skylinesaustralia.com/forums/post-a273103-
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
