I got some pretty decent wear on the inside of my tyres, I was going to get adjustable camber kits to sort some of that out. However I've seen a lower, and upper adjustable bar for the rear end.
I'll assume it's the "Upper" set for the fronts, but what do you guys normally use to adjust the rear? Upper or lower?
https://www.sau.com.au/forums/topic/325114-camber-adjustment/
Upper.
Also keep in mind that negative camber is not a bad thing, actually quite good for handling, just not too much of it for a car that spends most of it's time on the street. Toe in can counter some of the effects of negative camber and any good wheel aligner will know that.
I suggest, get yourself all the adjustable arms you can afford front and back and then find a competent wheel aligner and tell them what you want to come out of it with.
They'll then suggest what they think will work best for your usage of the vehicle and you'll settle on something in the middle. Tyre wear will soon tell you if you got it right or not.
Need any other help regarding wheel alignment specs etc. PM me.
Edited by BI6TIM
are there camber kits that can remove up to 1.5 possibly 2 degrees of camber? ideally ive been recommended to run a +0.5 but since skylines on average are at a -1.5, are there camber kits that can remove that much? my cars mostly drag orientated so im tryna counter the large negative camber that occurs on hard launches off the line.
Edited by Jap_Muscle
You should be able to get much less than -1.5deg camber but I don't know about +0.5deg. That's crazy anyway, if you run that sort of camber on the front you might go good on the drag strip but it will be a pig to drive on the street. No problem if it's track only.
I had the white line offset upper bush pins fitted to the rear upper arms and toe arms and with stock suspension I could get positive camber by simply adjusting the stock adjustment bolt and whiteline setups.,
The lower you make your car the more negative it will be due to the unequal suspension travel arks, ie shorter upper arms and longer lower arm.
You can get some offset bushes as said above, or another way to do it (yet more expensive) is the adjustable camber arms. Ive just fitted some KTS ones in my car and theyre perfect. KAZAMA also make them. Google or EBAY it and you'll know what Im on about
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
