Hey guys,
Front facing plenum means i now no longer have the standard window washer bottle in my R33. im after the little bag that can be used to replace the big plastic bottle
>>> or any info on where to source one <<<
i know the silver F&E automotive GTR has one but i dont know where to source one.
cheers.
https://www.sau.com.au/forums/topic/325524-flexible-window-washer-bag/
Hey Matt we both found one... Nice Products stock them but you'll need to check out their site to see the nearest retailer to you. Stock number: NWK901 and you should pay about $30
where in south aus could i get one i am also in this situation after installion of my plazmaman
  • 3 weeks later...
finally got around to installing mine, got the same one as partyboy, the NWK901 from norwood auto spares. delivered to sydney in under a week for 45 bucks all up.
(http://www.derek.com.au/washer.html if anyone else wants one)
really easy to install, about an hour of tinkering. the bracket they supplied i screwed to the fuse cover so the bag pretty much hangs in the position where the original plastic bottle would be. this kit comes with one plug and pair of wires so remember to splice it and connect it to both the nissan plugs if you have a rear window washer and want it to work from this bag as well.
cheap defect insurance, or in my case; cheap fix after a defect!
  • 11 months later...
Sorry to bump an old thread... was just wondering if you could explain how you wired up the pump in this kit to the factory OEM wiring.
I received mine late last week. The kit has a +/- Wire system, but Nissan Plugs iirc on the R34 have Three Wires. Did you just simply connect the single pump on the washer bug to the two sets of OEM wires in Parallel on just the + and - wires?
Thanks in advance
Nathan
Edit: Just realised this post was originally in a WTB thread.. mods let me know if I need to start a new topic elsewhere. Cheers
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
