Ok i have done a search, sounds like my cooling system may not be bled correctly.
Recently installed a new waterpump & fresh tested / cleaned radiator for my 26.
The car does not overheat at all when driving, however after stopping the overflow bottle starts to boil after a little while.
I filled up the coolant correctly (removed bleed screw etc) however to get the remaining air out it sounds like i may have to undo this bolt again when the car is hot / boiling after i stop? Just want to make sure this is safe enough to do.. or perhaps there is another way?
https://www.sau.com.au/forums/topic/325735-coolant-boil-bubble/
Cut the base off a coke bottle and tape the smaller side opening to your radiator filler (when cold). start the car then start tipping water into the coke bottle till its half way full and let it idle for a while.. it should bubble up releasing the air..
Cheers
Johno
Cheers
Johno
+1 thats the way to do it, just keeping filling till you get water coming out of the bleed screw.
probably not best to do when fully up to temp if you aren't confident. if you do decide to do it, have a rag wrapped around the area, or at least sitting over the top of the spanner. also you don't want to remove the bolt the whole way. you just want to loosen it enough that any air can escape, so you probably only need to loosen it a few turns. you will be able to tell once you are starting to get close to having it completely undone as the last few turns the bolt will be a bit wobbly in the thread, and also you will get coolant making it's way past the thread. the moment you get coolant starting to seep out then you don't need to loosen it off any further.
however i would do it when the car is only just coming up to temp. i wouldn't be doing after driving the car round for half an hour.
Cheers for the help. I bled it with this method this evening, took it for a drive - problem is still there when turned off!?
It doesn't go above 82 degrees whilst driving, even when giving some boot.
I am thinking that it might be corrosion in the cooling system? The radiator is clean as a whistle but inside the radiator pipes on motor side doesn't look too healthy. I have some cooling system flush on the way so will give this a whirl and see how i go.
I suppose the only other thing could be air getting into the system somewhere... in another thread someone mentioned the turbo water supply/return hoses.
Could it be anything else?
it is very hard for air to get into the system, because the system becomes pressurised when hot, so any places air could get in will have water squirting out of them. only real cause of air bubbles can be a dodgy water pump causing cavitation resulting in bubbles, or a blown head gasket.
it may be worth replacing your radiator cap and see if that makes any difference. just go a standard cap with the same pressure rating.
Yeah was also thinking the radiator cap. Always easy to overlook the simple things!
Replaced it last night - boil is gone :)
I heard a couple bubbles when it was cooling down. Probably just crap left over in system, getting engine flush next week.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
