  • Replies 44
without tune its costs massive on fuel
the way to describe the turbo whine is $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$!
i have a tiptrinic and i find it likes to shift to 4th and just slip winding boost to 5psi under slow or slight uphill applications, hoding gear in 2nd or 3rd sees at the same revs a locked trans and 10 - 20 inches of Hg - no boost
invest in an exhaust to hear your motor (not rediculously loud) and a boost guage because boost = cash
still tiptronic is fairly quick and easy to use, normally although sluggish responds quickly and shifts without jolts etc.
i'm looking to get a nistune but i see no point w/o electronic boost, dump, front mount, cold air, fuel pump until then its rather pointless as you cant milk the gains as much
but the stagea does not have a fuel economy figure - it has a fuel CONSUMPTION!
still a great car and one of the nicest things to drive, tows brilliantly, safe as, sounds fansastic with exhaust, heaps of room
even in stock trim its brilliant
ahh i was wondering what that extra wear was from....thanks carl :P
Thats why Commonwhore drivers, when they don't have passengers, place their upper torso over the centre console ... to even the weight distribution, so their fuel lasts longer and tyres last longer for those one peggers. :D
Thats why Commonwhore drivers, when they don't have passengers, place their upper torso over the centre console ... to even the weight distribution, so their fuel lasts longer and tyres last longer for those one peggers. :P
oh i see now....it all makes sense
Thats why Commonwhore drivers, when they don't have passengers, place their upper torso over the centre console ... to even the weight distribution, so their fuel lasts longer and tyres last longer for those one peggers. :thumbsup:
hey it works!
thats leboz in heck!k statos.... rofl
Hey i have had my stagea for over a year now. I have an auto, no mods and i use it as my daily drive from aldinga to glenelg and i get 520 to a tank. When i was driving from aldinga to the hub every day i was getting 550-570. I don't drive it hard but i still have a bit of fun. I love my stagea and i have owned a 33 before but totally wouldn't go back. I do have some rust under my mirrors but that is about it.
i never wanted something that had been modified.. as for price it has to be the cleanest low km stagea i've looked at in adleaide for that price. and in the flesh it is immaculate.. buying another modified car didn't interest me, been down that road before and your basically driving some body elses creation. all mods i want to do myself that way it's all mine.
That is a good price for a tidy stag. Right priced :)
Sounds like you're sold. Hurry up and get it then, so you can come on a stag cruise. :D
fuel consmption high in stags ey? i know why... coz every stag owner ive met before is an absolute nutcase hahaha they look normal till you show em some road... GOOONNNEEE
phuckers, look at ya awd volvo stealthness :D
Jealous much? :)
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
